You can try to use "tinyUmbrella" to see if cydia has you ssh on file..
tinyumbrella website
once you start the software you click the button save my ssh..
once it's done processing you can click on start tss server
This tss server will allow you to bypass itunes server which restricts downgrading firmware...
Once Tss server is running you can start itunes
once itunes detects your iphone shift + click on restore
Select the iphone 3g 4.0.1 firmware (goto http://www.felixbruns.de/iPod/firmware/ to download this)
Once it restores fully at the end it will give itunes error '1015'
dont worry..
Install Libusb if you dont have it..(Click here)
after installing libusb just use this program.. ih8snow
Click on "Fix recovery mode loop"
Click on yes to "do you have libusb installed??"
Select iphone 3g from the list
your iphone will reboot..
now you can first activate it ..
then you can use safari to goto Jailbreakme.com
slide the slider at the bottom...
it will download cydia
when cydia is installed you have to add "repo666.ultrasn0w.com" as a source
Its a zero "0" in the sn0w not "o"...
Search google how to add new sources.. to cydia..
Once you are done installing the application inside the repo666.ultrasn0w.com source your phone will be finally unlocked..
Of course easier way out would be to pay someone who knows how to do this..
regards
Which Country Your Mobile Locked now? There are Many ways to Unlock the I-Phone,I Choose the Best method Unlock code Unlocking...Because software Unlock leads to Data Lose..so that I choose the Unlock code the safe and secure method... .....I got the Unlock code at Reliable cost here http://www.onlinegsmunlock.com/apple-iphone-3g/rs7wp9/ and Unlocked it (I-Phone 35 Version)from Vivo Brazil Network.....Then You need to check code for Your Network...
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
SOURCE: Unlock iPhone 3g
I am forgot my iphone password so how can i do? and can i do by my self? please tell me the way to unlock this passwod?
When it comes to unlocking Iphones, Remote unlocking is the best method to be followed or used. . you can unlock your phone instantly within few minutes. This site Unlocking4U.com offers remote unlock for the iPhone. here are the instructions to follow while unlocking the iphone.
1. Allow us to send you an email saying that your phone has been activated or unlocked remotely.
2. Install the latest version of iTunes.
3. Make sure your iPhone 4 phone software is updated to the latest version using the iTunes software.
4. Connect your iPhone 4 Apple iTunes with a SIM card not accepted.
5. Wait until iTunes detects the iPhone 4.
6. 4 Disconnect the iPhone and reconnect after 10 seconds.
7. 4 Apple iPhone is unlocked.
