SOURCE: set up of the nintendo 64 console.
There is a big empty space on the back with a small plug on the inside. There should be a "power brick" that slides in there and then plugs into the wall.
SOURCE: game slot has been damaged on nintendo ds
I can give you some answers but might not work. See if the slot where the Ds game suppose to go needs to be cleaned.Take a pice of cotton from the cutip and put it on your stlyer(DS stick).Clean inside of it.Stiil dose not work and have a warranty go get the ds repaired.DO NOT PUT LIQUID IN THE DS SLOT(WILL NEVER WORK AGAIN TILL REPAIRED).
SOURCE: NINTENDO DOESN'T RECOGNISE GAMES IN SLOT
Clean the Ds slot. This happens to me alot, but I just blow into the slot and it works.
SOURCE: I have a Nintendo DS which has recently quit
someone probably messed with a game and put it in backwards and the console messed up probably send to nintendo good luck!
SOURCE: console blinks when game is loaded
Hi sounds like the common fault found with these old retro consoles, which is a worn out connector or dirty games recommend cleaning all your games with a game cartridge paste cleaner and replacing the connector pin with a new one. see http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/ they carry these items and included photo instructions.
