I have a technics FGservo sl-BD22 turntable I just got from a yardsale. It has the hum of not being grounded and it didnt come with that particular wire. It has some type of jack for the wire. Do I need to go out and buy a special wire, or can I just run any wire to the reciever if I can find some kind of jack that will fit it?
A grounding wire is just a piece of wire connected to an earth point on the deck, connecting to an earth point say on a radiator pipe. There's nothing special about this wire any old piece will do. You only need it if you get a hum noise when the turntable is connected to the amp.
presuming it has "some" effect, then gnd wire itself it good. Even though there may be a gnd thumbscrew on the preamp try slipping the ground wire under a screw on the main amp or receiver that screws into metal and make sure the gnd wire is touching metal under the screw.
if that didn't help, then you may have:
>a cartridge with an open gnd internally.
>an open gnd wire from the back of the cartridge to the outer shields of the RCA connectors.
>or your neutral & hot wires of your house wiring might be reversed causing something weird.
>a low quality preamp. (it should have a seperate wall adaptor so that only low voltage dc goes near the preamp)
good luck ground issues can be tough!
