Question about Motorola MR355R Two Way Radio
My motorola has an emergency alert button on top, when pressed and held it sounds an alarm on all other radios near it. we pushed it to test and it works well and is a cool feature. however, the call tone it was set on when we tried it, the coyote noise, sets off the alert on the other radio when we use it! whats going on?
  • Motorola Master
  • 1,655 Answers
Your radio may be functioning normally for the emergency alert. Here is an excerpt from the user guide:
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Posted on Oct 23, 2010
6ya staff
SOURCE:
How do I switch off the alarm on my CR1003 (model Number) Blaupunct bedside radio?
Setting the Alarm
1. Press and hold the 'Alarm/Sleep/Snooze' button to enter alarm mode.
2. 'Alarm Status' will be displayed and 'ON' or 'OFF' will flash on the second line of the display. Use the right hand rotary control to change the display to 'ON' or 'OFF' as required and press the right hand rotary control to confirm.
Stop the Alarm
When the alarm sounds press the 'Standby' button on the top of the radio. Alternatively, you can press 'Alarm/Sleep/Snooze' on the top of the radio.
Turn off the Alarm
Follow steps 1 and 2 in 'Setting the Alarm' and select 'OFF' in step 2.
Snooze function
When the alarm sounds, you can press the 'Alarm/Sleep/Snooze' button on the top of the radio. 'z' will be displayed in the bottom right of the display and the alarm will sound again in approximately 5 minutes.
Apr 16, 2017 | The Audio Players & Recorders
One handset is not responding and when pressed for long time the emergency alarm is turned on. Is there any reset button to troubleshoot this...?
remove battery for a few minutes and see if connections are clean- if when batteries are inserted and still have problem--- problem with mother
Jul 10, 2016 | Motorola MJ270R Two Way Radio
Set time on the sylvania Bluetooth radio scr1996-pl
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Mar 08, 2015 | Radio Communications
Battery connection on new alarm Light Your Way Smoke and Fire alarm
If the battery will not make a connection, it may not be installed properly. The connector requires firm pressure.
My First Alert instructions say to "press and hold the test button on the cover for 5-20 seconds, or until the alarm sounds".
Nov 07, 2013 | First Alert Sa304Cn3 Smoke Alarm Escape...
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
How do i program my eton fr 800 radio to come on automatically. Thank you.
  • To get your alert radio to come on when there is a weather alert first you needed to find the right NOAH frequency to turn on automatically to.
  1. Extend the antenna fully.
  2. Turn on the radio.
  3. .Press the "WB" button at the top of the radio.
  4. Turn up the volume and press the ^ or v button to cycle through all 7 of the weather channels.
  5. WB and CH will appear at the top of the display., with 1-7 next to CH.
  6. Select the strongest channel you can hear (if you can hear more than one channel. Usually only one channel is heard).
  7. The strongest one is the broadcast from your area.
  8. Now adjust the volume you want the radio to turn on in the event of an emergency.
  • Now once you have the weather frequency set for the radio to turn on to, we need to make it able come turn on in an emergency.
  1. Press the ALERT/WB button at the top of the radio.
  2. The alert light shines in the upper left corner of the radio.
  3. The audio will disappear but the radio is still on.
  4. It will monitor Noah until an emergency occurs and at that point a siren or a voice will alert you. Then you press the WB button to hear the alert.
Regards, Tony
Apr 27, 2011 | Audio Players & Recorders
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
Apr 09, 2009 | Midland 74-109 Weather Radio
Motorola BPR40 how to clone
How To Clone a BPR40 Radio
Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio.
2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice.
3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio
2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times.
3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures
1. Connect the cloning cable to both the Master and Slave radio.
2. Press and release Programmable Button 1 of the Slave radio.
3. Within 2 seconds Press and release Programmable Button 1 of the Master radio.
4. The LED for both radios show flashing orange during cloning.
5. Once cloning is completed, an
Mar 24, 2009 | Radio Communications
Set Clock
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
Motorola MR355R Two Way Radio Logo
1,052 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
