Based upon your description, the drain pump has either failed or the
pump filter has become clogged.
To check the pump, remove the bottom
access panel. There you will find access to the pump
clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and
discarding the water. When the water flow finally stops, completely
remove the clean-out filter. Inspect the clean-out filter, the drain
hose from the tub as well as inside the pump impeller for any additional
debris.
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Check the above link for an detailed answer for one of our senior experts...
