SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
SOURCE: ho spark on a pb 403t backpack blower
Well obviously you need to check the spark plug for fire. Try the old one first, then a new one. If you still don't have fire, then you probably burnt out the coil.
Jim
SOURCE: echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
