SOURCE: replace drum bearings on a Maytag MAH5500BWW
It depends on the installation. Is the area small?? How long would it take to clear the area for complete dissasembly?? After i had the machine all ready to be taken apart we charge 3 hours. Its not an easy job to say the least. However i personally own the same machine that i acquired and installed the new outer tub and seal. The seal comes with the new tub.
SOURCE: Maytag Legacy Series Leaking
I have the same problem as many other Maytag owners of this model machine have. I spoke to a repairman and he told me to "junk" the machine. He said the cost was about $300 to $350 to fix and he WOULD NOT guarantee his work on this machine. He said that Maytag knew of the problem but refused to do any sort of a recall.
My solution:
1. Buy another machine and junk the Matag
2. Tell all your frends and neighbors NOT TO BUY MAYTAG...
3. Drop the old machine off on the MAYTAG door step.
SOURCE: Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
SOURCE: maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
SOURCE: Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
