Did u mean u have put ur tv on timer...?
Do a hard reset
your problem has already been mentioned once in fixya.
see this link.
the solution given was
broken surface mount resistor of main power supply
and that represents a solved problem.
and hence your problem is same as the problem mentioned and so u also go by the same solution given.
also have a look at this solution and problem.
if not same as yours it reads similar one.
don't consider the model numbers too strictly.
sony has standard flashing codes for al its sets.
so u need not much worry about the model numbers.
just look at the problem and its solution.
dont forget to accept my solution if u go by it.
thank you
have a great day
good luck
bye
if time permits have a look at all our solutions provided by our site..
link
I'll let you know if the user manual is available.
Another thing can you please tell me the no. of flashes you can see?
can you please tell me the no. of flashes you can see?If you tell me the no. of flashes then i can tell you what exactly the problem is and a solution for it.
I have mentioned the list of no. of flashes and their solution:
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault
is 0 corrected, so if you don't clear them, you'll be seeing "old"
fault codes the
next time you enter this screen. Clearing is done by going into the
service mode ( display, channel, 5, volume plus, then power ) then
press 8 and Enter, which of course returns
everything to the factory preset condition.
is it possible to turn tv on manually? if it is, problem is with remote
control. if it isn't, i would bet its a problem with power supply. Get
out your DMM and measure the voltages in the
power supply. if it is too high, tv will not turn on.
I strongly recommend you to get it repaired.
In the power strip? Or on the back of the TV?
How would I turn off the timer?
