I have a replacement thermostat, how do I remove the existing temp sensor wire from the freezer and install the new one.
I asked a local repair shop. Just pull ******* the sensor wire and it will slip out of the tube through which it runs. Run the new wire which is attached to the new thermostat thru the same tube. Prior to purchasing the thermostat, I tested with a ohm meter for continuity ( there was none) and jumped the attaching power wires. The compressor ran verifying the problem with the thermostat. Thermostat cost $47.00.
