Question about Linksys Wireless-G WRT54G Router
How do I change the Upnp settings on my router?
I want to connect to Xbox live, and it says that this linksys router (WRT54G) connects if the Upnp setting is turned off. I dont know how even to acces the settings of the router.
  • Linksys Expert
  • 162 Answers
Linksys Routers are one of the best Home wireless routers. it has good security feature and better wireless length. To change the Upnp setting on your router
follow these steps
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1).Press Enter.
Step 2 The default username is admin (all lowercase) and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab then click Misc. to the left.
Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wirelessrouter, or select Disabled using the radio buttons to disable it.
Step 5 Click Apply and then click Continue to save the new settings.
Read more for setup linksys router
How To Setup Linksys Wireless Router In 5 Min Fixingblog com
Posted on Aug 25, 2018
    Master:
  • Linksys Master
  • 317 Answers
Do You have a problem with your Belkin Product? are you looking for Belkin Customer Support to Help you Troubleshoot your Belkin device? No Issues, We are going to Help you get the Belkin tech support in easiest way Possible. Knowing Pro & Cons of any customer service will Keep you prepared to get a hassle-free Customer service. let us brief you a bit about Belkin Inc. & Belkin Support. https://wirelessrouterexpert.com/customer-support/contact-belkin-customer-service
Posted on Aug 28, 2018
6ya staff
SOURCE:
Trying to connect to xbox live. It says to change my MTU setting to 1364 or higher.Ima computer idiot. tried admin blank password that didn't work please help
User is blank (left empty), admin is the password (when the Linksys is in default factory condition). Find MTU and change to manual and set to 1500 for broadband. Also, according to linksys, uPNP may not be compatible, so you may want to turn that off. Go to this link on Linksys to get a step-by-step setup for linksys routers and Xbox live. Also, pay special attention to section ii about upgrading your firmware to the latest version.
Jan 03, 2011 | Linksys Wireless-G WRT54G Router
Trying to connect to xbox live. Keep getting error that tells me to change my MTU to 1364 or higher. Im an idiot can you tell me how to change this setting. tried admin & blank password did not work....
If your Linksys is still in its factory condition, admin is the Password, leave the user blank. However, the issue may be the firmware version according to the Linksys site. Go to this link and follow the procedures for setting up your Linksys router and pay special attention to section ii and follow the link provided to ensure your firmware is up to date. If you don't want to update the firmware, then turn off uPNP and change the MTU setting to manual and 1500.
Hello i am trying to connect to me friend on xbox live with a WRT54GS linksys router and i unchecked the nat filter and the upnp is enabled but i still cant connect
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 20, 2010 | Linksys Wireless-G WRT54G Router...
My nat settings for my xbox 360 is set to strict, I am connected to xbox live from my laptop, my laptop is connected to my linksys router, how do i change my nat settings to open if my connection is set up...
You'll need to log into the linksys router and find the setting for UPNP. Please make sure this is enabled. That should allow your NAT setting to at least Moderate, if not Open.
Mar 12, 2010 | Microsoft Xbox 360 Console
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
The nat type for my xbox 360 is set to moderate
Enable UPnP.....UPnP can help make sure NAT works correctly for Xbox LIVE. Usually, this can be set on your router configuration web page, which is supplied by your router manufacturer.
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
Xbox Live won't connect when wireless is "secured"
Because your router is acting like a firewall, when in secured mode it only lets through the ports you explicelty specify. This is what all routers do.
Jan 07, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect xbox 360 to wireless router
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Dec 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
20,273 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
