Hi kirst_alers2 - From what you have described it sounds like you either have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor or drum. Lint or something else clogging the vent could be causing the dryer to take a longer time to dry the clothing. If the dryer is taking too long to dry then the issue may lie with a faulty sensor. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replaced depending if they are worn, damaged or loose. You can often locate a qualified tech through the manufacturer website.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
same
