First: Check the belt. A quick spray with some specific belt lubricant may fix the issue (or you could try another belt) or...
This could be a sign of bearing failure in these machines.If the belt solution above does not help then I would suggest having the machine serviced as failure to do so will just result in more damage being done. The noise you can hear is flat spots (damage) on a part of the bearing
