Question about Nero Multimedia Suite 10
My computer abruptly restarts when i install nero 10
  • 2,069 Answers
May be there is some conflicting software. also check for compatibility especially the OS bit version ( 32 or 64 ) etc
Posted on Oct 25, 2010
6ya staff
SOURCE:
I have Nero 11 on my XP3 computer. I bought a win 10 dell. I download to XP with upgrade charge $47.99, then transfer installer to my newwin 10 PC?
win 10 and win xp will clash and cause all sorts of problems as they are not compatible.
win xp is no longer supported by microsoft so consider leaving it out altogether
you can install your nero 11 on win 10 software and go to the properties tab and click on the compatibility tab , tick the box and highlight win 10 and apply
Apr 25, 2017 | Nero Computers & Internet
My laptop turns off when charged
Computer restart due to overheating:
Computer restarts due to over-heating when the processor fan goes faulty.Computer restart due to faulty RAM:
Computer restarts abruptly if RAM goes faulty, or if you install some in-compatible RAM or more than one RAM modules of different frequency or type.
Computer restart due to faulty Hard-disk:Faulty hard disk is one of the most common reasons for abrupt computer restart. Run a hard disk scan to fix this issue. If there are bad-sectors on your hard-disk, its the time to get it replaced. Computer restart due to overheating up of hard-disk:
Apr 05, 2012 | Computers & Internet
I install windows 7 now my nero doesn't run
The following Nero products are compatible with Windows 7:
Nero Multimedia Suite 10 Platinum HD
Nero Kwik Media
Nero Video Premium HD
Nero Vision Xtra
Nero BurningROM
Nero BackItUp & Burn (as of version 1.2.17)
Nero MediaHome 4
Nero BurnExpress
Nero 9 (as of version 9.4.26.0)
Sadly we have to inform you that any Version of Nero prior to Nero 9 will not officially be supported with Windows® 7.
You could try to change the way Nero is launched, but it may not work.
May 24, 2011 | Ahead Software Nero Express 6.0 (NERO6OEM)...
I have bought and installed Nero Multimedia 10. When I am trying to run it, it displays: "This application has failed to start because the application configuration is incorrect." Not even...
Try creating a super admin account. In command promt type this command: net user administrator /active:yes ......restart the pc after that. Then log in with the super admin account and try installing and running nero. Hope it will work.
Feb 17, 2011 | Ahead Software Nero 10 Multimedia Suite...
I can't install a new Nero 9 that I purchased. Keeps saying it cannot open an msi file
Is there a old copy of Nero 8 or such like older versions installed on your computer? If this is so, try uninstalling the older version first from your computer, restart your computer, then install the newer version of Nero 9. If this solution didn't help you.. then let us know again by replying on this post so that we can give you other solutions to help you most.
Dec 31, 2010 | Ahead Software Nero 6.6 (600901) for PC
This is the error message I receive when I try to view siles: This program requires the file advrcntr2.dll, which was not found on this system. What do I have to do to rectify the problem?
Most advrcntr2.dll "not found" errors are due to issues with the Nero CD and DVD burning software program. The advrcntr2.dll DLL file is a file that must exist in the correct folder for Nero to burn CDs or DVDs.
Most often the "This program requires the file advrcntr2.dll, which was not found on this system." error, are caused when, for whatever reason, the advrcntr2.dll file is deleted or moved from its proper location.
The advrcntr2.dll file might go "missing" because it was accidentally deleted from the folder, because an anti-virus or other security program mistakenly removed it thinking it was a security threat, or perhaps when you last upgraded or reinstalled Nero.
Do not, under any circumstances, download the advrcntr2.dll file from any "DLL download site." There are several reasons that downloading DLLs from these sites are never a good idea. (If you've already downloaded advrcntr2.dll from one of those DLL download sites, remove it from wherever you copied it to and continue with the following steps).
Restart your computer. The advrcntr2.dll error might be a fluke and a simple restart could clear it up completely.
Record the serial number of your particular Nero installation. Follow these instructions on Nero's site for locating the serial number to your particular Nero version.
If you can't find your Nero serial number using Nero's instructions a product key finder program could help. (here is one that may help: http://download.cnet.com/Keyfinder-2010/3000-2094_4-75183881.html?tag=mncol;2 )
Uninstall Nero from your computer.
Be sure to uninstall using the Uninstall Nero link in the Nero program group (if available) or use the Programs or Add/Remove Programs utility in Control Panel.
Download the Nero General CleanTool utility ( http://www.nero.com/enu/tools-utilities.html ). Install and run this free program from Nero. This utility will ensure that Nero is 100% removed from your computer.
Restart your computer again, just to be safe.
Reinstall Nero from your original installation CD or downloaded file. Hopefully, this step should restore the advrcntr2.dll file.
Install the latest update to your Nero program if there is one available. There may have been certain issues in your original version of Nero that caused the advrcntr2.dll error you've been seeing.
Restart your computer again.
Run a virus/malware scan of your entire system if the Nero reinstallation steps don't resolve your issue. Some advrcntr2.dll issues can actually be related to hostile programs that masquerade as the advrcntr2.dll file.
Note: The advrcntr2.dll file should be located in the C:\Program Files\Common Files\Ahead\Lib folder. If you find the advrcntr2.dll file in the C:\Windows or C:\Windows\System32 folder, chances are it is not Nero's legitimate advrcntr2.dll file.
Hope this helps you.
Nov 27, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Sir, Pl. help me- I have installed "Nero Burnlite
Does your XP requirements satisfy the requirements at the link page?
System requirements for XP installing Nero 10. -> LINK.
If it does not then you have to update your XP windows system first before installing Nero 10.
Hope it helps.
Nov 25, 2010 | Computers & Internet
I cannot uninstall nero 7 and it is disturning me
I would suggest downloading the Nero clean tool from here
Install it onto your computer then run the program.
This will do a complete uninstall / removal of Nero 7.
Aug 11, 2010 | Computers & Internet
How can i remove the fatal error in my nero 10
hello welcome to fixya,first uninstall your nero from control panel->remove programs
and then install nero 10 again from the cd you have or setup file you have and everything will be fine
Jul 24, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Dvd rom cant read cd/dvd
It may be that its went to meet is maker,and you will have to replace it .If its prone to dust or smoke you could try cleaning it .If you use Nero Burning Rom,look inyour Start Menu/All Programs/Nero. In the sub menu click on Nero Tools and then select Nero Info Tool and see what that brings up.Hope this helps.
Regards Bill
Feb 19, 2010 | IBM Computers & Internet
Computers & Internet Logo
144 people viewed this question
Top Nero Computers & Internet Experts
Vernon Taylor
john h
shaun
shaun
Are you a Nero Computer and Internet Expert? Answer questions, earn points and help others
