Question about Miele Novotronic T230C Electric Dryer
The empty container/pc light comes on after approx 5 mins of drying cycle even when the container is empty
    New Friend:
At the back of the dryer there should be a plastic tube from top to bottom ( this is the overflow pipe from the water container that needs to be emptied after each use, if the container is allowed to fill up, the water gts picked up by this pipe and collects at the base of the machine, stupid idea, i know) undo the clip at the bottom and empty the tube, also, with the tube still of, tilt the dryer and if loads of water comes out where u disconnected the tube you just need to get the water out. re connect the tube and bobs your uncle. hope this helps. p.s u may want to remove the top cover ( 2 screws ) and blow down the tube to make sure it aint blocked. when re fitting the tube, dont be scared of bending it to get it back into the slot where it tucks into the machine
Posted on Dec 05, 2010
Testimonial: "thankyou very mutch, this was exactly the problem. i have done what you told me to do and that has cured the fault. thanks again. charles."
  • frodmyster Dec 05, 2010
    also, the heater ( which is behind the observation panel at the back ( 4 screws ) could be damp, remove the cover, if the back of the cover has what looks like condensation on it, unscrew the 2 screws holding the heater in place, pull it out so u can see the elements and have a go at it with a hair dryer to dry it out and also heat it up ( you do not have to remove any of the wires. before re fitting the back panel, just screw the heater into place and test the dryer to see if the heater kicks in
    New Friend:
Thank you so much. My familiy is happy the heater is working.
Kind regards from Germany
Posted on Nov 21, 2013
Anonymous
SOURCE:
The LED back lights will not stay on. I have sound and I can see an image with a flashlight.
inverter board is most likely the culprit since it feeds power to the backlights.
Jun 08, 2016 | LG Televison & Video
After drying a load of rather damp clothes, the 'emty out container' light keeps coming on (there is a loud peeping noise and the dryer stops) even though the container is empty. The container is not...
This may help you. Please give the person who answered this thread credit if this helps.
http://www.fixya.com/support/t277592-bosch_classixx_condenser_drier
Apr 07, 2011 | Dryers
Lost the instructions / booklet and cannot recall how to clean / descale my DeLonghi ( Magnifica Model) Coffee Machine. Are you able to assist? Many thanks
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Feb 06, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
9 times out of 10 start ups no voice ,it comes on 5 min.later approx gently tap rear of cabinet sometimes works
Check the circuit board for dry solder joints. Dry solder joints are quite common in TV's. the other thing is possibly a leaky electrolytic capacitor in the audio circuit or power supply
Jul 05, 2010 | Philips Televison & Video
Problems with the display
this means that the dryer is in an auto dry cycle.
Sep 02, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Open Questions:
See all Miele Novotronic T230C Electric Dryer Questions
Miele Novotronic T230C Electric Dryer Logo
877 people viewed this question
Top Miele Dryers Experts
Mike
peter gittos
peter gittos
Dw Wooten
Dw Wooten
Are you a Miele Dryer Expert? Answer questions, earn points and help others
