Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
While watching it, the screen went black (totally). Sound was still there but no pic. When I tried a different channel to see if it was cable or tv, it shut off. Now the green light will come on and the screen flashes blue for about 1 second and you can see the message in the upper corner "No signal". Then it shuts right back off. I tried a DVD in it and it plays the sound but still a black screen. What happened?
  • Vicki Mathews
    Vicki Mathews Dec 18, 2012
    It turned out to be a diode, which cost about $1 to get a new one. Our son gave us this hint and how to go about fixing it. It worked great!
  • Akai Master
  • 8,457 Answers
The tv have a long board call a LCD inverter board.This LCD long inverter board,it dead.This long LCD inverter board,help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Posted on Oct 25, 2010
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 33 Answers
SOURCE: The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Posted on Feb 19, 2009
Is the tv shot or just a bulb? it went out suddenly
Standard CRT televisions as in your category don't have a 'bulb' they have a CRT, a Cathode Ray Tube. If there was sound and no picture, something was defective in the video part of the circuitry, now no sound, so something else has blown. 2004, 11 years old, old technology, and HEAVY and bulky. Technology has moved on, and you will be surprised how much. We went from 36" CRT to Samsung 50" Smart TV. HUGE difference! Treat yourself :>)
Sep 13, 2015 | Televison & Video
I have a Phillips plasma tv model number 42PF5521D/10 serial number VN4B0708013071 i was watching it on 1 of the 2 hdmi channels when all of a sudden it just went off when I turned it back on all I had was...
Does it work on the cable/antenna input jack? Can you get the menu screen to show up? If none of the inputs work and you can't get a menu screen to show up, then it sounds like you may have a bad YSUS driver board.
Mar 21, 2014 | Televison & Video
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
I was trying to hook up a DVD player via the Component 1 and I also tried the Component 2, when hooked up I got a picture and perfect sound but the screen was like watching a black and white pic. It may...
i would not recommend it other than maybe a keyboard duster, the problems your are encountering sounds like cable issue symptoms. have you tried swapping out the cable.
May 29, 2011 | Televison & Video
Screen went black while watching, now ony have sound
Look at the venting grills, you should see whit lights inside the set. If not, the backlight inverter board may have gone out or the power supply supplying the power to the inverter board may have gone out. Those are the two places to look first. It may have bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
Haier Plasma Tv Screen went black
This model has several defective boards and eprom chip. There is an upgrade kit. I'll attach the kit part number and upgrade instructions. http://service.haieramerica.com/documents/SB-TV-0003.pdf
Feb 20, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
195 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
