Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
Posted on Oct 25, 2010
How do I know that my disposal is actually working? It sounds right but I just had a clog after the displosal and it looked like good size pieces of food were passed right thru the disosal. Is the top grinder supposed to spin around freely?
A
Anonymous
The top grinder is supposed to spin around freely.
When something gets stuck:
Turn off switch.
Stick a wood broom handle down into disposal.
Wedge broom handle against sink opening and push grinder disk until it spins freely.
If you get stuff in the disposal like broken glass:
Stick vacuum hose in and remove the glass or bones, or whatever.
Most disposals will chew up chicken bones.
But heavier bones will not go down without considerable racket.
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 • Dishwashers
tip
How to unclog a garbage disposal
Before you tackle this problem, you should understand how to use your disposer so you'll probably never have to deal with a clog again. You can easily use put a sinkfull of waste down your disposer without a hitch. It's all about controlling the amount of water mixed in with the waste. Your disposer is designed to break waste down to pieces a little smaller than a BB. This is efficient but without much water, the pieces will clump together right where the disposer connects to the drain line, and will cause a clog. Never turn on the disposer without a full flow of cold water. Cold water not only helps to cool the motor, but keeps any fat solidified so that it doesn't build up on the walls of the pipes. The full flow of water will allow the disposer to mix the waste in and it'll go right down the drain. The second thing you must control is the amount of waste that goes in the disposer. It's really a bad idea to put more than like half a cup of waste in the disposer without it running. Ideally you'd turn on the water first, then start the disposer, then feed the waste in. Listen to the disposer running with waste in it. It sounds different when the waste inside is gone. Use this to get yourself used to keeping up with its pace. The problem with any disposer is that they work so fast, they can grind the waste faster than the water can carry it away.
Whatever you do, don't use a chemical unclogging product. Over time, this can damage the metal components of the disposer, and if you have to call a plumber, they will charge you extra because these chemicals make their equipment wear prematurely and can burn the skin.
If water doesn't drain, make sure the problem isn't fixed by simply turning the disposal on. If the water just swirls around, you'll probably need a plunger. When you want to use a plunger to unclog your disposal, the easiest way is to use suction more than pressure. When you push down on the plunger, the pressure from it will cause the backed-up waste to compress even further and make it impossible to push water down. You want to push the plunger down so that it "leaks" water out, and, when the plunger can be pushed down no farther, make sure it then has a good seal on the disposal's opening, and yank the plunger up pretty hard. This will pull the backed up waste back, mixing it with the water and will probably unclog the unit in only a couple strokes. Be careful not to soak yourself when pulling up on the plunger. In a pinch, a full soda can will actually form a seal and can be used in place of a plunger for disposals that have a splash guard made of one piece. If water is backed up into the other sink bowl, that means the clog is in the trap and not in the disposer itself. One way to fix this is to make sure the other bowl(s) of the sink are firmly stopped up. If you use a stopper you'll most likely have to push down hard on the stopper while plunging the disposer to form a good seal. If none of this helps, you may need to take apart the sink trap. This can be done by loosening the two nuts on the part of the drain pipe assembly shaped like a "U". You then may be able to clean the clog directly out of the u-bend or you may need to snake the pipes. If you take the pipes apart, have a bucket under there to catch the large amount of that will gush out.
on Dec 07, 2009 • Plumbing
Sink garbage disposal not working! when I switch the garbage disposal on, nothing happens!
Do you hear a humming sound when you turn it on? If so, you have a clogged disposal. Check on the bottom for the allen wrench location recessed in the middle of the disposal. Insert the proper size allen wrench and you'll be able to rotate the motor back and forth (sometimes difficult at first) and eventually loosen the clog and free up the motor. If you're able to move the shaft/motor easily in the beginning and it still doesn't work you may have a defective disposal. If you want to check more thoroughly you'll need to check to see if you have power at the disposal when you turn on the switch. Use a electrical tester that you can buy at any home improvement store to see if you have power at the disposal. If so, and the motor turns easily when you use your allen wrench, you have a defective disposal and it needs replacement.
2helpful
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Overflow draining to the sink
it's supposed to drain out the same drain pipe your sink uses. If it is overflowing into your sink, then your drain pipe is clogged. Your sink probably overflows when your disposal runs too, right? Unclog your pipe and you're good to go.
4helpful
Dishwasher wont drain
Depending on the age of your dishwasher, it could be either a directdrive or forward reversing type. We've had both. Direct drive dishwasherssimply keep going as the water drains but forward-reversing ones havemotors which stop and then start (moving in the opposite direction) todrain water out of the dishwasher. It helps to know what type ofmachine you have. Obviously, if the motor isn't reversing properly,that could be the cause of a problem right there. But let's hope thatis not the case.
Next, think about whether you've installeda garbage disposal recently and if the dishwasher stopped drainingright after you installed the disposal.
Many dishwasherswon't drain or seem clogged after a garbage disposal is added to thesink area. Happily, this is not only a common problem but one which isusually resolved quickly. You'll simply have to check a piece calledthe knock-out plug. You can see what that looks like here: www.applianceaid.com/food.html#plug
Okay,so was your disposal installed without taking out the knockout plug?Oops! Simply remove it and you are good to go. Your dishwasher shouldnow drain smoothly. Simple.
GE Triton won't drain completely
Hi Tina! (say Hi to the Family, too)
Your drain hose from the dishwasher (DW) was installed incorrectly after the DW was moved back into place. Good news!!! Easy fix. All it takes is a 5/16" nut driver (or socket) and some vinyl electrical tape.
Look under the sink, you'll see the white drain hose hooked up to (most likely) your disposal. You'll notice that it just kinda slopes downhill 'til it disappears through the cabinet, right? Well, the slope in question is actually the culprit! It's siphoning water from your sink and down into the DW. Everytime you run water in the sink, some of it goes over to your DW instead of down the drain. Go figure, right?
Here's the fix... You have to re-route your drain line to make it have an upside down "J" in it before it connects to the disposal.
Use your 5/16 and loosen the clamp at the disposal and remove the hose. Pull on the hose to get as much slack as you can from the DW and into where you're working. Now route the hose between the sinks (the recessed area there underneath) and THEN into the disposal. Now tighten the hose clamp to secure the hose to the disposal. For extra measure, use your tape to secure the hose to a water line in the back by the water valves.
Seriously easy job, Tina and Family. Maybe 15 minutes.
SG
1helpful
2answers
How do you unclog the hose to a whirlpool gold dishwasher? It overflows into my sink. I have checked the hose and there doesn't appear to be a clog.
I had this same problem and solved it. The black rubber hose leading from my Disposal to the overflow vent on the sink corner was clogged. You will need to remove the hose via 2 hose clamps and scrape out the nasty gunk inside. Did I say Nasty???? I meant NASTY! I used a straight piece of 1/2" conduit to scrape the inside walls and then pushed a piece of rag through it again and again till it was clean. Don't forget to check the disposal nipple which leads into the grinding chamber. That thing was nastily clogged on mine. Had to use a knife or something (I don't recal) to scrape out the walls of this 2-3" deep opening. Works like a charm now.
I'll save you some trouble.....I took apart the vent and the dishwasher hose all for not! They were clean as a whistle. It was that dang disposal cauding all the problems.
Good luck! Hope this helps!
Greg
Dishwasher won't drain after having replaced sink
Sounds like it may be a dime.LOL Take a scewdriver and gently tape this metal piece .To the left or right,up or down.See if it moves.
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
