Question about Quinny Buzz Jogger
Need a 255x50 tire - Quinny Buzz Jogger
Will 17" rim fit 19" rim like some models have
When changing rim sizes, you need to manage the "height" of the tire to compensate. Usually folks are shifting to larger rims so to keep the circumference the same, a lower profile tire is used. If you are going from 19s to 17s, you will need a much "taller" tire. I believe Tire Rack has a calculator that can help with tire selection. Tire Tech Information Tire Size Conversion Chart
Dec 29, 2014 | Cars & Trucks
I need to know what my tire pressure should be on my 2006 Lexus ES350
the tire pressure is listed on the tires. The tire pressure is determined by the tire itself so you will need to look at the actual tire you should see numbers like 16/205/60r and another number like 44psi you need the number with psi following it and that will tell you your Pounds per Square Inch needed for the correct pressure
Jan 16, 2013 | Cars & Trucks
Need tires for barely driven truck.
truck tires and car tires differ more on the load rating of tire. Go to google and type in 'UTQG'. In the search results select the 'How stuff works' link, they have an excellent explanation of tire ratings. Check tire-easy.com and tirerack.com for tires to fit your truck. I strongly recommend that you do not use passenger car tires on your truck, the soft construction of these tires will make your truck unstable while driving. Hope this helps, let me know.
Jul 25, 2010 | 1997 Ford Escort
Had a flat tire on my GMC Sonoma. Changed the
wheel rim damaged ?? locating pin for wheel not lined up
May 16, 2010 | 1993 Nissan Altima
Tirepressurelightcomeson
Ad air into your tires (evenly). After that you need to reset the tire pressure (cpu) to read your tire pressure accurately.
Underneath your steering wheel is a button. Press and hold this button for about 5 seconds then release it. The "check tire pressure" like should start blinking and then turn off. You need to drive at least 8 miles before the computer will let you know for sure if you need to put more air in one of your tires. Also the check tire pressure light only comes on if your tires are about 8 psi apart. Hope this helps.
Jan 23, 2010 | 1997 Pontiac Grand Prix
Tire pressure
Seance the car manufactures most likely did not produce the tires that are on the vehicle they will only give there recommendations as to the correct tire pressure. Always look around the perimeter of the tire and it will tell you the proper pressure for that tire. hope this helps. Good luck.
May 30, 2009 | 2004 Chevrolet Malibu
Need to lower the tire pressure of Toyota Tundra ?
What was the problem you faced when you tried to lower the tire pressure? Why would you need to lower the tire pressure unless 1 tire was over filled if it was low to begin with? You do NOT need to change the tire pressure for summer or winter months. The tire pressure amount should be the same all year.
Jan 11, 2009 | 2007 Toyota FJ Cruiser
Tires
Front and rear tires are different. Check your owners manual for the correct tire sizes.
Nov 20, 2008 | 1990 Suzuki RGV 250 L
Quinny Buzz Jogger Logo
66 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
