Kyocera Copystar CS-1820 Black and White Copier Logo
Anonymous Posted on Oct 26, 2010
Error code c6400 on fs-1118 mfp - Kyocera Copystar CS-1820 Black and White Copier
MSM
Level 2:
New Friend:
  • Expert 165 Answers
  • Posted on Nov 04, 2010
MSM
Expert
Level 2:
New Friend:
Answers
165
Questions
0
Helped
76570
Points
291
Fuser temperature over /under u need service engineer to reset it
1helpful
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Resettare codice errore c6 su kyocera fs 1118
If the code is C6400, then just follow the procedure showing in the images below.
If the code is C6000, then you have to remove the fuser unit and check the thermistor, the thermal cut out and the heater lamp. If are able to fix the problem-damage, then follow the procedure below to reset the service call.
b6abe89e-6db1-403f-b1d5-10039126b726.jpg 6bbf89df-5e1f-4ba9-830e-5fa3e278ce55.jpg
1helpful
Error c6400 solution
Zero-cross signal error,While fuser heater ON/OFF control is performed, the zero-cross signal is not input within 3 s. The problem is; Defective PWB, replace the engine PWB or power source PWB and check for correct operation.
1helpful
Fs-1118 mfp printer error code c3200 for solustion
UNLOCK THE SCANNER LOCK SWITCH ON THE PRINTER WORKING.
1helpful
C6020
my copier kyocera fs-1118 mfp display error code C6020 please help me the solution.
2answers
8helpful
Kyocera FS1118, error code C6400, how do I resolve This?
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
21helpful
3answers
SOLVING ERROR CODES
i have problem in my copy machin kyocera fs-1118  this problem is erreur c6400
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
