Good day,
Yes, the new high efficiency units tend to run a lot compared to older models. That in fact is not a bad thing, since the compressor has to cycle on and off fewer times per day, and starting and stopping are what create wear and tear on refrigeration equipment. Actually you pay less because of the much smaller compressor that uses less power.
However, keep an eye on it. If it gets continually worse going forward, call for service. Hopefully Frigidaire has solved it's problems but was known to develop internal restrictions in the refrigeration system causing that problem to the point it runs continuously and fails to cool properly.
If the machine is under 5 years of age it would be corrected free of charge.
