Had the drill for 9 months batteries not charging. the light on the charger is on like its charging but changes to say battery full after a couple of mins and batteries aren,t charged.i have 2 batteries same problem with both.
I DON'T KNOW. COULD BE UNDER WARRANTY FOR FREE REPAIR OR REPLACEMENT. I HAVE RYOBI AND UPDATED ITEMS. THEY HAVE 3 CHARGERS 2 SMALLER RATED CHARGERS WOULD NOT GIVE ME
'FULL CHARGED' LIGHT. OLD BATTERIES WOULD NOT CHARGE ON OLDER CHARGER. FROM INTERNET ADVICE, I REPEATEDLY PLUG AND UNPLUG CHARGER BY HAVING PLUG LOOSE WHEN DOING THIS. SOMETIMES IT TAKES 4 TIMES TO CHANGE FROM DEFECTIVE TO CHARGE. SOMETIMES IT TAKES 20 TIMES TO SEE THE CHARGE LIGHT.
To maximize your battery life let them cool down 15 minutes before you put them on the charger.Also let them cool down after charging before use for 15 minutes.Store your batteries with a full charge and condition them every month by using them a little bit and return them to the charger for a full charge.
If it is a Lithium battery, the charger will have a tester built into it that will show a problem if there is one. Let it charge for a couple of days to see if will ever show a full charge.
remove the battery from drill and insert into the charger, the red charge light should come on and then after about an hour it should change to green indicating a full charge, there is a lable on the charger to indicate other problems that might occur. Let me know if you need more assistance.
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
I think you've already come to this conclusion, so I'll affirm, you need a new battery.
Something that may be worth trying, if you haven't already, find something a little abrasive and try to really scrub the contacts on the drill, and in the charger, ( obviously you'll want to make sure the charger is unplugged.)
It may be the charger, but most likely
the battery can no longer hold a charge.
This may happen if the battery drops
below its holding charge. Example,
left discharge for a couple months.
There is little that can go wrong with a
charger unless you start smelling
burnt plastic from it.
Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
