Olympus Camedia C-60 Zoom Digital Camera Logo
Posted on Jun 09, 2008
Flash standby symbol and orange light flash continuously
On startup the red flash standby symbol and orange light flash all the time so I presume it's failing to charge the flash. Sometimes it stops after a minute or two but resumes after taking a picture. The battery is fully charged. The only way I can use the camera is with the flash turned off.
Lyndiy
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 07, 2013
Lyndiy
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
218
Points
I have the same problem. Can anyone help me with this. :(
A
Anonymous
Try another battery. Take the camera to a shop to try the battery before you buy just to make sure. Rechargeable batteries do eventually die, especially if you don't give them the full charge up time. If you only ever give your battery a quick charge you induce a 'chemical memory' which makes the battery work for only a short time despite showing a full charge.
  • Lyndiy Sep 07, 2013
    Have you already solved the problem with this? Im using Olympus FE-5010 and I got same problem with you. Please give me updates. Thank You!
  • mickswinburn Sep 07, 2013
    For some reason my camera has improved without me doing anything. It still takes about 30 seconds when first switching on but after that it's ok. I haven't changed the battery or any settings.
A
Anonymous
2answers
Panasonic standby light blinks Red/Orange why?
set is trying to move from standby to power supply on and not making it, No model indicated so best advice is take to some shop and get an estimate.
3helpful
2answers
Flashing light opposite ink symbol
Indicating cartridge faulty/exhausted, replace the cartridge..
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
When i try to turn it on i get picture and sound for about 2 seconds and then it shuts off and the red light flashes,
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
5helpful
2answers
Red blinking light
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Sony TV will not come on
hello my friend, that flashing light is indicating that you have a problem in the horizontal ckt, more likely is a defective diode
[email protected]
7helpful
3answers
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
