SOURCE: My Magellan maestro 3225 wont charge or start up
Same here - the problem, at least with mine, is that the power pin on the unit has become loose and not making contact with the machine - thus will not charge most likely from pluging and unplugging it in multiple times and breaking the connection inside the unit - FWIW, this GPS a real piece of **** and I have already replaced it with a Garmin- I'm trying to figure out how to take it apart to see if I can solder the power pin back in place but it is not as easy as removing the 4 back screws...
SOURCE: Hi accidentaly remove application folder on
If it won't connect then about all you can try is a hard reset. That will force it to reload all of the applications and reset it back to factory default condition. You would loose any waypoints and routes etc that you haven't saved but it should work just fine after that.
SOURCE: HI, I have Magellan Maestro
Hi Geoloui,
If you're looking for the Magellan Maestro Applications you can download it here. Please click on the link below and you will be directed to the Magellan's official support download site. They all have the complete software application together with instructions on how to install them. Please follow the basic steps below on how to download the application.
1. Go to this site: Magellan
2. You need to download the Content Manager so your Magellan GPS navigator can deliver new map and updates and product information.
3. After downloading, install the Content Manager to your computer.
4. Turn on your GPS. You need to wait for the menu to appear then connect to your Computer using the USB cable provided.
5. Content manager will automatically prompt you about the update. If Content Manager does not prompt you, right click on the Content Manager icon located in the system tray and select "Check for updates now". Content Manager will inform you if you have the latest software already installed.
--> the system tray is located in the lower right hand corner of your computer screen near the clock.
Hope it helps.
Thank you for using FixYa.
