ATI RADEON 9200 Graphic Card Logo
Anonymous Posted on Oct 27, 2010
If i connect the DVI cable to my Video card (9200 family)and to my monitor an Asus VH222H i get a dialogue box saying no DVI signal. if i use the VGA cable everything works fine.Does this mean the card will not run DVI? or do I have another problem?
sentsignal7
Level 2:
  • Expert 186 Answers
  • Posted on Oct 27, 2010
sentsignal7
Expert
Level 2:
Answers
186
Questions
Helped
41175
Points
666
Make sure your monitor is set up to recieve what ever signal you are wanting via the monitor's menu. There should be an input button on the monitor to select the signal type. The connection really doesn't matter as long as you are able to use the monitor. There could be something wrong with the connector on the video card. Also make sure you are using the card and are not using the onboard graphics connection by mistake. If the problem persists it is more than likely the card.
Testimonial: "Thanks"
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4991
Points
TRY ANOTHER DVI CABLE ,
CHECK THE MODE OF THE MONOTOR
RUN THE WINDOWS OS IN VGA MODE STANDRT
Anonymous
Level 3:
  • Master 32,281 Answers
Anonymous
Master
Level 3:
Answers
32281
Questions
Helped
7911771
Points
102259
If the monitor has a DVI connector then it should work. Go into the monitor's setting and switch the video input from VGA to DVI.
  • Anonymous Oct 27, 2010
    sorry. The monitor has VGA DVI
    If you connect the DVI cable from your video card to the monitor then your video card has DVI output and will work with a monitor with a DVI input/connector.
    Is there something wrong with my answer to earn a "NOT HELPFUL" rating.
    May be your question does not contain sufficient information for me to help you.
2answers
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Have a ASUS VW222U LCD monitor and works fine with the DVI input using a Macbook. Now I want to connect the VGA port to a ACER netbook and all I got is 'No signal'. The on screen menu don't work if no...
2007 monitor not dead, a rare thing , that.
well RTM the manual shows how to change input ports
from DVI to VGA,
most LCD the OSD menu button does that the manual is free to read,
like this
asus.com, i click search for.:
VW222U https://dlcdnets.asus.com/pub/ASUS/LCD%20Monitors/User%20Guide/e3157_vw202-222.pdf
page 15 said
When both the VGA and the DVI cables are connected, you can choose either
VGA mode or DVI mode from the Input Select item of the OSD functions.
and Page 19
clear as day?
When i added a video card.. and restarted my pc. a blue screen appears... saying "overun"?? what is the problem??
well did you check weather the video card came with a VGA pin where you can connect the monitor signal cable if not , connect the monitor signal cable to the video card VGA out socket.
good luck
1helpful
2answers
Cannot get second monitor output to work on ATI Radeon X1200
A DVI-D signal is digital (whereas DVi-I is digital AND analogue) and can never be converted into a VGA signal without using expensive hardware boxes that convert the signal. These though tend to lose quite a bit of the signal quality. If I were you I'd look for a monitor with a digital connection, because I'm afraid this isn't going to work.
I'm sorry your problem can't be fixed...
Yannick.
@DickcanFixit: Catalyst 9.4 is the most recent.
2answers
Monitor says No signal digital
Is ether the monitor or video card uses both DVI or VGA port. There may be a switch on the graphic card that changes it from DVI to VGA, often outside the card.
Also is the computer monitor set to the right setting if it can use both VGA and DVI, if using DVI (of any type) it need to switch to digital, and if using VGA it need to be set to analog. This may be a physical switch or using the settings button. (see manual how to change them)
PS: VGA port is a blue D shaped port with 15 pin holes, and DVI is a white rectangle port with one port being a line.
Monitor Problem
Well assuming you used the same video cable when you tested the monitor on the Asus PC you?re left with: - Physical problem with the Asus video card. - Asus video card configuration problem. - BIOS configuration problem - Possibly a problem with the DVI/VGA adaptor depending on the answer below. A couple of questions about the Asus before we start: - I?m not sure I understand how the DVI/VGA converter figures into this. Is your cable coming off the monitor DVI thus you need it to plug into the Asus VGA connector? If yes who is the manufacturer of the device and what model do you have? - Has the Asus worked in the past with another monitor or is this new? - What is its history/configuration?
Top ATI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
