Removing stains from tennis shoes.Most modern tennis shoes are made out of easy-to-clean material, and can be cleaned off with warm water, soap, and some scrubbing. More soiled shoes can be cleaned with a commercial cleaning solution. Bleach and glycerin can also make a good shoe-cleaning substances if mixed correctly
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:
Materials you'll need:
1. Mild soap or detergent
2. Soft brush or toothbrush
3. White vinegar or baking soda (optional)
4. Water
5. Clean cloth or sponge
6. Old newspapers or paper towels
Steps:
1. Remove Loose Dirt:
Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.
2. Remove Laces:
Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.
3. Pre-treat Stains:
If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.
4. Soak Laces:
If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.
5. Wash Shoes:
Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.
6. Rinse Thoroughly:
Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.
7. Dry Properly:
Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.
8. Clean Soles:
Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.
9. Protect and Maintain:
Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.
10. Polish (for Leather Shoes):
If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.
Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
Any shoe repair shop will have products that can clean this. If it is leather or suede, there is a product here called 911 that is agood cleaner. You may not have that there. Tana and Fiebings make products of this line. You can find them at places in the yellow pages - shoe repair
