The error code you gave shows several possibilities for your issue:
Drum charge corona wire, The output of the charge corona wire of the black PCU is abnormal.
Causes
• CGB power pack connection loose, broken defective • Check CGB power pack connection to BCU • CGB power pack defective • BCU defective • Replace OPC drum
Of the five possibilities above, replacing the drum is the most likely cause. Since you only had your drum for a couple of weeks I would take it back to where you purchased it and ask for replacement. Sometimes you get a bad drum out of the box from the manufacturer. It happens. If the same error code pops up again, I recommend you call your local Ricoh dealer for further troubleshooting.
If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
SC 670 - Engine response error. After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
solution found on copytechnet.com sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
sc670 is an engine startup error. A lot of times if you reset the copier (turn it off with the orange switch on the left side of the front cover, then turn it back on) the error will go away. If it doesn't the BCU board may need to be replaced.
