Toshiba 61H70 61" Rear Projection Television Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue gun adjustment does not move blue line in menu convergence function. Any way to adjust or fix?
Chi Chu
Level 3:
  • Toshiba Master 8,457 Answers
  • Posted on Oct 28, 2010
Chi Chu
Toshiba Master
Level 3:
Answers
8457
Questions
0
Helped
2822773
Points
26282
No.Fix.Tv have dead parts on the tv convergence board.Tv colors lines R,G,B mis alignment,can't move any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead on the tv convergence board.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
1helpful
Double image on television with blue hue
<SPAN id=ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution>Projection <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>TV</FONT></A> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>3D</FONT></A>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <BR><BR>This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <BR><BR><B>Common Symptoms include....</B><BR><UL class=h_mi><LI class=h_mi>Screen looks 3D <LI class=h_mi>Colors don't line up <LI class=h_mi>One or more colors can't be adjusted when using the convergence menu. <LI class=h_mi>Screen is bowed or warped. <LI class=h_mi>TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </LI></UL>Here are some <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>photos</FONT></A> of convergence problems.<BR><BR><IMG class=h_mi src="/uploads/images/42D3683.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/7859B01.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/E87380C.jpg"><BR><B>Here is a quick tes</B><B>t....</B><BR><BR>Using your original remote go-to the settings menu then goto the convergence section.<BR><BR>Try to adjust the red and then the blue convergence.<BR><BR>You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <BR><BR>If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <BR><BR>Note: If you TV has as flash <A href="http://www.fixya.com/#" target=_blank><FONT color=#0033cc>focus</FONT></A> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<BR><BR><B><IMG class=h_mi src="/uploads/images/69189A5.png">CONVERGENCE SOLUTION<BR><BR></B>You can see some more examples and find a fix using this link on Fixya <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</FONT></A></SPAN>
1helpful
Blue line convergence not working
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Projection <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">TV</a> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">3D</a>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <br /><br />This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <br /><br /><b>Common Symptoms include....</b><br /> <ul class="h_mi"> <li class="h_mi">Screen looks 3D <li class="h_mi">Colors don't line up <li class="h_mi">One or more colors can't be adjusted when using the convergence menu. <li class="h_mi">Screen is bowed or warped. <li class="h_mi">TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </li></ul>Here are some <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">photos</a> of convergence problems.<br /><br /><img class="h_mi" src="/uploads/images/42D3683.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/7859B01.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/E87380C.jpg" /><br /><b>Here is a quick tes</b><b>t....</b><br /><br />Using your original remote go-to the settings menu then goto the convergence section.<br /><br />Try to adjust the red and then the blue convergence.<br /><br />You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <br /><br />If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <br /><br />Note: If you TV has as flash <a href="http://www.fixya.com/#" target="_blank">focus</a> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<br /><br /><b><img class="h_mi" src="/uploads/images/69189A5.png" />CONVERGENCE SOLUTION<br /><br /></b>You can see some more examples and find a fix using this link on Fixya <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target="_blank">http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</a></span>
Colors have separated and are wavy. It seems that maybe the guns are out of sync.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Blue and red wavey lines and distorted picture
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
We can cet the blue and green adjusted but not the red. It like watching tv in 3D
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Convergance the green is all over the place!!
  • Screen looks 3D
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
1helpful
Red gun convergence problem
  • Screen looks 3D
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
