Re: Have a problem to log in account in fixya. It shows...
Hi, send a mail to the community manager in person of Lauren Chang at [email protected]
She will refer your problem to the technical department and it will be resolved.
This is common issue that sometimes you cannot login to Facebook, And as this is a generic problem so it can be solved by any step given below:
This may happens,when someone else is logged on or
trying to log on to your Facebook. Maybe you didn't log off all the way
last time you signed on. Check the last computer you logged in with and
make sure your logged out.
This problem may be occur when you try to log in to Facebook to that location like Schools, Universities, Offices etc. where shared users has intentionally blocked Facebook.com login page using Windows host file, In this case you can't log in to Facebook, Then to open Facebook, Use free proxies but do it on your own risk
This may happens when your browser need to be deleting the cache memory so for it, Go to your browser ''Options' and 'Delete the cookies and all the browsing history' then Reboot your PC and then try to login again.
May be you are using the wrong details to login.Use the email address which you
receive your Facebook notifications and enter correct password, If you have doubt that you have forgotten your password then click on "forgot your password" then follow the steps that will be on your
screen.
If you still can't login then may be you are disabled from the Facebook, First check for any possible reason why disable the account, If its really disabled then Just open the following link, Give all the related information which is required and it can help you to enabled your account. CLICK HEREIf you want to activate directly your account then All you have to do is send an email todisabled@facebook.com or You can report a bug via the Facebook website by following these instructions:1. Click on Help Center in the bottom right hand corner of your screen.2. Click on the Topic that most closely relates to the problem you
are having. You may need to drill down a few times but you should
eventually see the link in the next step 3. Click on Bugs & Known Problems. 4. Click on "I would like to submit a bug report".5. Click the link in this statement when you see it, "Please submit bug reports only here".6. Fill out the form and submit it.After sending mail or bug report , your account will be enabled in less than 3 hours then you will able to Log in your account.
Anymore help i am here to help. If it is HELPFUL then your token of appreciation in the form of FOUR THUMBS (given below to this solution) will be esteemed. Thanks and keep visiting FixYa Concerned: Angel Bird
If you wish the log out pr sign out of your Facebook account, click the "Account" tab at the top-right of the Facebook page and select "Logout" from the drop-down menu. (See attached image)
For more help and clarifications, please feel free to reply to this post.
Hope this solves your problem. Thanks for using FixYa.
If you wish the log out of the Facebook, kindly click the "Account" tab at the top-right of the Facebook page and select "Logout" from the drop-down menu. (See attached image)
To sign out or log out of your Facebook account, kindly click the 'Account' tab at the top-right of the Facebook page and then select 'Logout' from the drop-down menu. (See attached image)
To log out or sign off from your Facebook account (so that another person can login), kindly click the 'Account' tab at the top-right of the Facebook page and then select 'Logout' from the drop-down menu. (See attached image)
To sign off or log out of your Facebook account, kindly click the 'Account' tab at the top-right of the Facebook page and then select 'Logout' from the drop-down menu. (See attached image)
If you wish the log out or sign out of the Facebook, kindly click the "Account" tab at the top-right of the Facebook page and select "Logout" from the drop-down menu. (See attached image)
You will have to first log-out of your sister's Facebook account and then sign-in to your account using your user name and password.
To log out of the Facebook account, click on the "Account" link on the top-right corner of the page and then select "Logout" from the drop-down menu. (see attached image.)
Solution is simple. Close Messanger. Go to
Users\<USER>\AppData\Local\Microsoft\Windows Live Contacts and
remove EVERYTHING there, start messanger again and this bug is gone!
