The player is in theft lock out, A secuity code was entered by the original owner as they do not come locked, u must contact Eclipse for instructions to reset the code, if it can be done at all, they will require proof of ownership.
Hello there, not sure if someone else has mentioned this yet or not, but this deck is locked and if it will not accept a cd then it needs to have the security code entered by the manufacturer to unlock the deck. Unfortunately this is the only way to fix this deck, you will need to contact Eclipse at 1-800-233-2216 and they can arrange for the deck to be unlocked and if need be the cd mechanism to be repaired. It should take a CD but if it will not then it has larger problems going on here.
Please let me know if you have more questions about this scenario, just reply to my answer here I will be glad to help.
Sorry about the situation you are in, not sure how it has happened, but that is what needs to be done to rectify it.
Thanks so much,
Tim
Have you tried this?
http://www.ehow.com/how_7284149_unlock-security-eclipse-cd-player.html
Http://www.eclipse-web.com/us/index.html
Above is a support link for Eclipse.
Whenever that error code is displayed, it indicates that the laser head assembly cannot read the media correctly and it is not able to access the Sectors correctly, thus cannot "Read" the Media content.
As for a fix? Well you could try a "Cleaning" CD, this may help especially if it is just a dirty lens etc. However usually it is the entire head assembly, the laser and or the quadrant detector has faulted.
It is not a difficult repair providing you have a service manual, the spare parts, and the tools required. However it may cost more in spare parts than it costs to replace the unit.
What you need to do, is take the unit to a reputable repair center and ask them for a "Quote" as to the repair. This will at least enable you to make an informed decision as to repair or replace.
Hi. It is actually the security disk. The security CD is the 1st CD you put in after reset.
For example: If you go to the shop and have the radio reset. On the way home you put in Jimi Hendrix, that CD becomes your security CD. You better have that CD the next time you change your battery, or you'll be going back to the shop to have your radio reset.
All Eclipse brand radios have a feature called ESN (Eclipse Security
Network) installed. This means a Key CD may be inserted into the head
unit so that if the unit is stolen or battey is disconnected from the
unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You
installed it in your car and you wanted to activate the ESN security
feature. You need to choose anyone of your cd's from your collection,
lets say you chose The Offsping, Conspiracy of One. Input the disc hit
the correct buttons ( I'll explain those later) and your Eclipse 54400's
ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400
into his car and it will show SEC [disc], so he/she will insert a cd
and it will say [ERR]. If he or she does this 5 times it will show [call
800] which will lead them to Eclipse customer service, but you will
have already called eclipse and told them that your unit was stolen.
Whether you get your head unit back is highly doubtful but nobody else
will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and
hold Radio station preset 1 and the FM-AM button for more than one
second 3. Insert the CD of your choice. A [SEC] message will now aooear
on the screen and ESN is active. Anytime the unit loses power you will
have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM
button (make sure the tuner is on). 2. Press and hold the radio station
preset button 1 and the FM-AM for more than one second. 3.Once the
display flashes [disc] insert the key cd you selected to activate the
ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the
correct CD is inserted your display will read [---] and the cd will
begin to play. If the wrong CD is inserted it will display [Err]. If you
insert the wrong CD 5 times it will say [call 800] and then you have to
send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio
preset button 4 and the FM-AM button for more than a second and the
display should show your 8 digit serial number. This number is to
identify your unit if it is recovered after being stolen. Yep, that will
happen!
Keep in
mind that the "security code" in a radio basically fulfills this
function, ensure that in case of theft, the computer does not work in
another vehicle; I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you
get on the internet, Eclipse dealers, ask for the parts
counter, tell them you need your radio code, have your serial number
handy as well as all other numbers off the radio housing.
Or, call
1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of
the security code for a $25 charge. the number being displayed is
probably the serial number of your unit. If you can remove your radio
the SN will be on a tag.
Hope this helps.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts there. Cause for two blinks of standby light with Sony sets are described in detail. Check it.
No button or button combination on the panel changes the screen from:
Unit will accept a CD but will not play it.
It shouldn't matter but my model number is #CD3434.
SEC
8D201399
Alan D
Nothing has changed....
Stuck on
SEC
HELP
then
SEC
8D201399
Alan
Nothing has changed.............????????????????
Tried all combinations!
Alan D
Haven't heard from you??????????
Still locked out........
displays
5D201399
Alan D
Won't power up. Displays SEC /
Problem with the CD3422 CD Player
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
Dragon
I may not have been clear about my problem.........
The entire radio won't power up. I did not mean just the CD.
The display shows only what I put in my original Q.
My past experience is that the FM-AM will work on radios even it the CD is kaputz.
It seems that since the radio was without power 12v for a period of time that it could need reset by pushing some buttons. No FM-AM / Display etc. I have pushed all the buttons and nothing changes.
Alan
Still no one has contacted me recently???
Same problem!!!!!!!!
I was not very clear on my problem.
Please reread my inquiries.
I need to reword my problem.........
MY ECLIPSE RADIO fm/am/cd IS NOT WORKING.
NO DISPLAY OF ANYTHING EXCEPT THE SED MESSAGE.
Alan
My CD is not locked...........
Let me know when you have read all of my comments...........
MY RADIO FM/AM DOES NOT COME ON.......... THE CD WILL ACCEPT A CD AND REJECT IT ON COMMAND. MY PROBLEM IS AS PREVIOUSLY DESCRIBED.........
Alan D.
Alan D.
My Radio is still locked on SEC / 8D201399
No buttons work except the CD eject button.
NO FM/AM
NO SOUND
NO LIGHTS EXCEPT
SEC
8D201399
NOTE I NEVER ACCEPTED ANY FIXYA RESPONSES. YET YOU HAVE TAKEN $12.00 FROM MY CHECKING ACCOUNT.
Capt Alan Deutschmann
cell: 314.581.0514
My CD is not locked........... Let me know when you have read all of my comments........... MY RADIO FM/AM DOES NOT COME ON.......... THE CD WILL ACCEPT A CD AND REJECT IT ON COMMAND. MY PROBLEM IS AS PREVIOUSLY DESCRIBED......... Alan D.
•alan2go•posted now
My CD is not locked........... Let me know when you have read all of my comments........... MY RADIO FM/AM DOES NOT COME ON.......... THE CD WILL ACCEPT A CD AND REJECT IT ON COMMAND. MY PROBLEM IS AS PREVIOUSLY DESCRIBED......... Alan D. Next1 ...
2345
Previous Thank You!Was the solution helpful?Show your appreciation by commenting on Won't power up. Displays SEC /:
I don't want to Accept this solution
•Continue working with this Expert by posting more comments - Reply to micromatikal
•No, I want to work with a new Expert - Ask Another Expert
X
Are you sure you want to withdraw your problem?You should only withdraw your problem if no Expert is giving you a satisfactory solution for this problem, and you would like to post another problem. If you want to continue working on this problem with another Expert, Go Back, and pick the Ask Another Expert option. back
Need additional assistance?
•Get Answers from our Top In Dash Receiver Expert
