Testimonial: "found link last night. it worked perfectly and fixed problem. Thanks."
To scan from the device control panel (direct connect)
1. Load the original.
2. Press the left arrow or the right arrow to select the Scan function, and then
press OK.
3. Press the right arrow to select what to do with the scan, and then press OK.
4. Press Start.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
This
is the step on how to scan docs using HP J4680:
1.
Press the "Power" button on the HP J4680 and lift the top
cover. Place the document to be scanned on the scanner glass. Be
sure the document is face down and properly aligned with the top,
left-hand corner of the glass.
2.
Use the arrow keys on the control panel of the HP J4680 to select
the "Scan" feature. Press "OK" to continue. Then
Press the right arrow to select the scan feature. Press the "Start"
button to begin the scan.
If you need more help come back.Post /
welcome!
