Samsung HT-X250 Theater System Logo
Posted on Oct 29, 2010
I have Samsung HT-X250 and was trying to upgrade the firmware. But, during the upgrading there was power cut of, and it seems that the firmware on my Samsung HT-X250 doesn't finish upgrading process correctly. Now it doesn't recognize the DVD's, CD's and doesn't eject it. Is it some way to work it around and to upgrade the firmware directly from PC?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
831
Points
Did you sort this out?
1. Samsung HT-X200 does not switch on 2. How to upgrade HT-X200(2.1) to HT-X250(5.1)
Hi JOHN MATHEW
1.Your Samsung HT-X200, has power supply problems and problems with audio output
2. To convert your Samsung HT-X200 (2.1) to an HT-X250 (5.1), you must add a DSP, several amplifier stages, one for each channel added
You will find it cheaper to replace your Samsung HT-X200 (2.1) with a Samsung
HT-X250 (5.1)
Hola JOHN MATHEW
1.Tu Samsung HT-X200, tiene problemas de fuente de alimentacion y o problemas en la salida de audio
2. Para convertir tu Samsung HT-X200(2.1) a un HT-X250(5.1), deberas agregarle un DSP, varias etapas amplificadoras, una por cada canal agregado
Te va a resultar mas economico reemplazar tu Samsung HT-X200(2.1) por un Samsung
HT-X250(5.1)
https://elektrotanya.com/samsung_ht-x200_ht-x250.pdf/download.html
Samsung ht-c6930w
Latest firmware is..
HTB-C6930WWB-1016.2.zip
This can be downloaded (with instructions) at http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SIA00201&prd_ia_cd=802&prd_mdl_cd=HT-C6930W%2FXEU&prd_mdl_name=HT-C6930W%2FXEU&srchword=HT-C6930+3D+Blu-ray+5.1+Home+Entertainment+System
If you already have this firmware then you need to contact Samsung.. The last upgrade was 5th oct 2012.. not good enough Samsung.. :(
Factory reset for ht-q20??
1. RESET
While "NO DISC" message appears on the display of main unit, hold the main unit's STOP button for longer than 5 seconds. "INITIALIZE" appears on the display and all settings will return to the default values.
Using the RESET function will erase all stored settings.
2. Firmware update
Upgrade File ver 1.3, All OS (ENGLISH) 18 Sep, 2007
Upgrade guide ver -, All OS (ENGLISH) 21 May, 2007
HT Q20
Samsung HT Q20 firmware update
HT Q20
1helpful
Samsung sf-650 intermittently sends a blank page
Print configuration report "Menu>Reports>Configuration/System Data"
Check the firmware version. 1.07 or lower is likely to have this problem
Upgrading the firmware is quite simple.
Get the update from samsung website Samsung.com>Support>Search Box "SF-650">on product support page find tab "firmware" and download upgrade file.
If you feel competent to do the upgrade (read the instructions in the txt file twice) do it.
Be aware that the upgrade will likely want to do a memory clear once it is complete so you will loose address book etc. Also do not power off unit during upgrade or you will damage the firmware and possibly make the unit unusable.
Hope this fixes the issue.
RECEIVES FAXES OK, BUT ONLY SENDS BLANK SHEET
My samsung dvd writer is reading cds but not dvds what should i do
Caution: Samsung is not responsable for problems during the firmware upgrade.
When you encounter problems during the upgrade, please contact a Samsung Service Center.
If your drive is still in warranty please contact your retailer first. When you upgrade your firmware, please check the "Buyer" on your label of drive.
If you upgrade wrong firmware, you will have a problem in operating.
ex) SM-332B/*** 63BT123456 F/W=T403(***=Buyer)
■■ How to upgrade firmware ■■ 1. Download the attached "Bin file(firmware)" and "Sfdnwin.exe file(download
program)" into a temporary folder. 2. When you run "Sfdnwin.exe", Pop-up window will appear. you can see your ROM-
drive(s) in the Pop-up window.
Then choose the drive whose firmware you want to upgrade.
ex)Drive:SAMSUNG CD-R/RW SM-332B/T403 3. You will see three icons on the top from left.
If you click the first icon from left, you can see "Investigation window" then open
the firmware file that you already downloaded to the temporary folder. 4. You will see the message" Ready" after finding the firmware file that you want.
Then click the middle icon on the top of left. Then your firmware will be upgraded
automatically. 5. When you finish upgrading firmware , reboot your pc automatically.
■■Sfdnwin.exe : A program which can make your drive download our firmware(s) in Windows.
(It's for only Windows)
I had the same exact problem and thought the ROM was broke but it still played CD's. It's funny because when the problem started I thought I had really messed something up, and it turns out there are massive forums like these for the exact same problems. I hope I can ease a few minds w/ this. I'm running Windows XP, 1G ram, 100GHD.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
