Question about Ricoh Aficio 2015 Copier
I cant find the scanner driver of ricoh Aficio 2015,, please suggest me
    New Friend:
  • 165 Answers
The copier does not use driver
u need to connect it using network cable (cross over if its only to one computer)
assigne ip address subnet mask and gate details
connec to the copier via ur web brouser ising that ip address
log in user name admin no password
go to address book and set up a user and the path to where u wana save
plus domain name workgroup all authenticatin detail and have a shared folder on ur computer with read and write rites enabled
sorry to say this but if u r not fammilia with connectivity side of things ull find it very difficult
Posted on Nov 13, 2010
6ya staff
SOURCE:
I have Ricoh aficio 2015, it showing error code sc-114, please how do I clear the code.
you can make a brush air to the scanner and clean the mirror
if not
replace the ccd
Nov 12, 2016 | Ricoh - AFICIO 2015 Printer
The ir 3235 is displaying E000280 - 003 i want to know the cause of this fault
ricoh aficio 2105 error code 32836 the scanner is not working please help soon
Sep 06, 2011 | Ricoh Aficio 2015 Copier
Hello, I have a problem with RICOH Aficio 2015.
look check that motor bottle is rolling and toner home place is sending toner to drum
Mar 23, 2011 | Ricoh Aficio 2015 Copier
We want our ricoh aficio 2015 as a network printer what type of interface we required?.
first u have to purchase feature expantion or GW board from ricoh if it has been already installed in d machine just download the rpcs driver from www.ricoh.com
and install to ur pc
Apr 21, 2010 | Ricoh Aficio 2015 Copier
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
Scanner
i would need to know how exactly is everything set up. obviously, if the settings are not set right, it won't work.
Apr 02, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
238 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
