Does it aggitate??
the safety button is most likely broken, you can see the small hole where the figer pushes down to stop the spin cycle, if the washer does not aggitate, then most likely it the safety switch.
get it replace, or bypass(not adviseable) but only when you need it,
Water that doesnt move tend to get stinky fast!
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
SOURCE: GE WASHER WCSR2090 will not
Fix to problem might be simple such as cleaning out the inlet filter. Remove hose from machine and look inside machine side of connection. There is a cone shaped screen that can be removed and cleaned. Some times the screen stay attached to the hose end, so if you do not see it in the machine, look at hose.
Thanks for using
FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering
your FREE question.
Harder may be that the water inlet valve is defective and does not open. You can check this by reversing the hoses and see if you get hot water when you fill the machine on cold setting.
SOURCE: After using a washer cleaner
Here are my guidance notes for a number of problems with possible poor, or no, drainage symptoms-
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
