Dewalt 7.2-18.0 Volt One Hour Charger Logo
Posted on Oct 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Got de9501 batt and won't fit de9701 charger - Dewalt 7.2-18.0 Volt One Hour Charger
Level 3:
  • Dewalt Master 7,733 Answers
  • Posted on Nov 02, 2010
Dewalt Master
Level 3:
Answers
7733
Questions
0
Helped
1863230
Points
21487
G'Day.. I have a Plega Traveller, (it no longer
Sounds like one or both of the batteries has a high internal resistance. Bad batteries, perhaps? Have you LOAD tested or tested for internal resistance? Could be why charger is shutting off so soon.
Voltage isn't the only test for these types of batteries.
I have a Jet3 wheelchair not charging with internal (accoring to amp meter)
you will need a off-board charger to charge the chair Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Batt.in my elect. wheel chair will not start charge
how dead are the batteries. some chargers won"t charge until a certain voltage threshold is met as a safety measure
Batt won't charge
Please check the charger if it can charge other similar phone. Also check if connector is ok.
Toshiba satellite battery won't charge
DID YOU NOTICE ANY OVER HEAT IN BOTH,THE PC OR CHARGER? IF SO THE CAN BE 2 ISSUES.
1-THE CHARGER
2-THE BAT
IF YOU TRY TO CONNECT THE CHARGER WITHOUT THE BATT,THE CHARGER GET HOT? (1) ,DO THE CHARGER IS OK (2)
2helpful
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
2answers
I want to connect an automotive external battery to my apc 500 es ups. plz help how to do it
You may be able to do this but it may NOT charge the external battery, you will have to see.... Anyway simply connect the battery up to the inside terminals Red- Red Black - Black.. with suitable wire & fittings make sure you have no shorts etc. ya good to go.
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
