Cobra 29 LTD CB Radio Logo
Posted on Oct 30, 2010
I get weather and it seems to be getting out but nothing else,don't guess I'm holding my mouth right.Been awhile since I have been in a truck.
2002 buick lesabre transmission sensor bad
This is no transmission sensor problem, it is a mechanical issue in the transmission.
How much oil does a 1998 swift hold
best guess, most cars hold about 5 quarts. if you are changing the oil, put in 4 quarts and then check the level after you start the car and let it run for a minute. don't check it right away. give it a minute for the oil to get back down to the oil pan.
2helpful
My a/c only works sometimes and after it has been running for awhile it stops blowing cold air
My guess is that the refrigerant is low.... and it seems the leak isn't too bad. Below a certain point there's a safety switch the won't let the a/c work if not enough pressure. It appears that your truck is right near that level. A can of refrigerant with a gauge runs about $20 ... I'll guess you'll need half can or so to get the charge back in to the normal range.
Car lights, dash lights, tac, radio and clock all go out but
Look for missing or loose grounds. LOAD test the battery, holding a charge and ability to perform are two different things.
Doc
Can't get audio on Bearcat 244CLT scanner, or get any of the buttons to operate properly. Can set the clock, but that's it. Volume and Squelch set all the way to right, not even static sound. Nothing on...
You can try a master reset. This will delete any frequencies that are programmed. Here is the way to do a reset...
Turn scanner off. Hold down, 2-9-HOLD (all three keys at once)while turning on the scanner. Keep holding the keys down for about 3 seconds. The word CLEAr should come up on the screen.
Brake lights/ Turning signals not working on a 2004 cavalier
change brake light switch . check brake switch wiring . for shorting then check tail light bulbs sockets. if you cant find it. you probably going have to buy a short finder.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
