Are you worried as to why there is no Water in the Water Tank/Bucket at all?
Well, a few operational basics must be understood by you please.
For the unit to remove moisture from the air and draw water into the bucket/tank, the set relative humidity (%RH) must be below the current or ambient room relative humidity.
Attempt to lower or reduce the setting you have to a lower value and it should start collecting water in the tank.
Hope this helps
SOURCE: My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
SOURCE: I want to change my deLonghi Dehumidifier from
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Testimonial: "Very helpfyl I think. I will se when I get home where the drilling needs to occur."
SOURCE: My DeLonghi DEM10 Dehumidifier not producing water.
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: My DeLonghi Portable Dehumidifier Model
First, make sure the reservoir is empty. If you plug the unit in and
see a green power light, but the unit won't run, make sure the
reservoir is properly inserted. Many dehumidifiers have switches or
sensors to make sure that the reservoir is placed so that it won't
leak. Look for these sensors and make sure the reservoir is engaging
them. If your dehumidifier has a float or switch to indicate a full
reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
