> can I connect an external hard-drive to it?
Probably.
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
Use Norton Ghost or some similar Hard Drive cloning utility to "clone" your existing Hard Drive to the external drive. Try Hiren's Ultimate Boot Disk (available for download for free on the 'net). It should have several utilities that can help you out.
1 ***** the size of
files you need for taking the backup. Files having graphics, sound and videos
occupy more space than a simple text file.
2 Plan the future
requirements and consider the space needed accordingly.
3 Choose an
external drive of 20 GB or above to store huge data backups.
4 Get an external hard
drive and connecting cables to attach the drive to your computer.
5 Select the data you
want for backup. Organize the data into folders and sub-folders for easy find.
Financial data, digital photos and music can form priority data for backup.
6 Connect the drive
to your computer. Use the drag and drop options for taking the backup.
7 Remove the drive
after properly ejecting by right clicking on the task bar on the desktop.
8 Keep the external
drive away from the place where you have your computer when done. If your
computer gets damaged due to any unforeseen reason, you will have your entire
data safe in the external hard drive. It minimizes the risk of data loss.
