Start with checking that the dryer has 220volts to it. You can have a 2 legged circuit breaker half tripped, which will allow the light to come on and the drum to spin, but no heat. Next you should check the element for continuity. If that isnt the cause, then it most likely will be a thermal cutoff. If you go to sears parts direct, you can put in your model # and get a complete breakdown, with part #s and all.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
