Check to see if the scanner lock is on lock position.. If it move to unlock
C3100 Scanner carriage problem The home position is not correct when the power is turned on or copying the document placed on the contact glass.
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
C3100 Scanner carriage problem The home position is not correct when the power is turned on or at the start of copying using the table. Poor contact in the connector terminals. Check the connection of connector YC4 on the scanner PWB and the connector on the scanner home position switch, and the continuity across the connector terminals. Repair or replace if necessary. Defective scanner PWB. Replace the scanner PWB and check for correct operation. Defective scanner home position switch. Replace the scanner home position switch. Defective scanner motor. Replace the scanner motor. The mirror frame, exposure lamp, or scanner wire is defective. Check if the mirror flames and exposure lamp are on the rail. And check the scanner wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
c3100 is a scanner home position error, does the scanner move when turned on with lid up? if not its the motor, if it moves then it mat be a sensor (usually "U" shaped in rear left under glass, or it could be "locked" for shipping, look for a switch on left side or under scanner unit. hope this helps.
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
