Question about Dean Vendetta XM Electric Guitar
How to put a whammy/tremolo bar on this guitar?
    President:
  • 1,140 Answers
This model comes with a whammy;http://www.deanguitars.com/home.php If you have the one at this link:http://guitars.musiciansfriend.com/product/Dean-Vendetta-XM-Electric-Guitar?sku=512150 You are better off saving money and getting the one at the first link. Here is why Parts:http://www.stewmac.com/shop/Bridges,_tailpieces/Electric_guitar_tremolos/Floyd_Rose_tremolos_and_parts.html Routing:http://www.stewmac.com/freeinfo/Hardware_installation/Guitar_hardware/i-1119.html or http://www.stewmac.com/freeinfo/Hardware_installation/Guitar_hardware/i-1118.html You need the tools and skills necessary to take a guitar that has a different bridge system and install a tremelo system.
Posted on Nov 02, 2010
6ya staff
SOURCE:
Unstable tuning, also goes high in pitch, I replaced tuners, permanent vibration in the sound
Look for something related to the whammy bar causing unstable tuning. The only other thing is string QUALITY and gauge. Use the recommended strings for the guitar.
Aug 25, 2011 | Gretsch Guitars G5122 Double Cutaway...
Bridge: the guitar keeps getting out of tune. Should I block it with a piece of wood, making it more like a fixed bridge?
Do NOT modify the guitar. Take it to a shop where they can set it up properly if you are having intonation or clearance problems. Also the quality of strings has a lot to do with changes in tuning. It is NOT uncommon for a guitar to require tuning during a half hour of playing. This is normal, especially if you are really driving it. Temperature affects the tuning drastically as well.
Apr 11, 2011 | Ibanez RG370DX Electric Guitar
Hi , what type & size of whammy bar do i need to replace a standard yamaha erg 121 please. thanks Becky
Any standard screw in whammy will work they're the same as a stock Fender Strat.
Good luck, Cody J.
Dec 12, 2010 | Yamaha Electric Guitar
I have a Fender Squier Strat. The Whammy bar is
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Mar 08, 2010 | Fender Squier Std Strat Mn Car
Tremolo arm installation on b.c. rich warbeast
There will be a threaded hole on the tremolo block. The tremolo arm simply screws into this.
Dec 25, 2009 | B.C. Rich Wmd Warbeast Electric Guitar
Need a wammy bar for a V-Tone Behringer Electric Guitar
whammy bars are available at musiciansfriend.com it looks like you have a strat copy they will need to know that
Oct 11, 2009 | Behringer Consumer Guitar Package
SChecter c1 plus tuning problems
If you do a lot of bends or use a whammy bar this will happen a lot. The best way to keep a guitar in tune is to buy a locking system to put on it. I use a floyd locking system for my own guitar.
Sep 07, 2009 | Schecter C 1 Plus Electric Guitar Cherry
Need help putting my guitar together
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 10, 2009 | Fender Squier Std Strat Mn Car
My Dean razorback V Standard keeps going out of tune and I have no clue how to fix it.
First, I don't know how long you've been playing guitar but you need to make sure the strings aren't old and/or not kept clean. The oils and skin cells from our fingers will cause strings to break down in there elasticity, therefore causing them to lose there retention (eg. memory). If you have a locking system with floating bridge then make sure your locks are tight, but not to tight as to strip or break the screws. Next, if you have a cheaper guitar, like in the $250 range, you will experience this more often than not, especially if you don't have a locking system. But just remember that guitars have to be retuned all the time (just watch live video of guitarists like Jimmy Page and Angus Young, etc.) if you play a lot and really play the instrument to the fullest (eg. Dive Bombs, EVH Horsie, Pitch Bends, etc.). Also, when you put on new strings they need time to stretch before they find that place where they retain their memory so it's a good idea to play and stretch the strings using various techniques like bending and whammy (EVH has been known to boil his strings to aid in this). Last, but not quite the least, if you find your guitar going out of tune after just a few minutes and after all my suggestions then your guitar may have a problem with its INTONATION, which you'll need to take it to a guitar technician which won't cost much and you'll be very happy with the sound. One last thing to remember, if you have a cheaper guitar without locking system they're really not capable or designed for using the whammy bar that comes with most of them---this is just a feature for helping to sell the guitar because everyone wants a whammy bar---the guitar will go considerably out of tune everytime it's used. Hope this long explanation helps.
Dec 09, 2008 | Dean Razorback Db Electric Guitar
Question
Best recommendation : Bigsby or a Stretsbar - check your local guitar shop for prices (varies depending on location)
Nov 05, 2008 | Epiphone Les Paul Studio Electric Guitar
Dean Vendetta XM Electric Guitar Logo
479 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
STEVE
Are you a Dean Music Expert? Answer questions, earn points and help others
