Claxtonbrent That is the error code for a bad right brake and it will have to be replaced. There is no quick fix for this problem. It requires a new brake and I'm not sure if you can replace just the brake Usually when I get this and Medicare is paying for the repair I have to order a right motor/gearbox assembly. you can contact Invacare @ 1-800-333-6900 ask for M51 tech support and ask if you can replace just the brake Hope this helps
The 4½
minute interval can be changed to 1½, 2½ or 3½ minutes as follows:
Press and hold the Lock button until the light blinks (about 10
seconds). A single blink indicates the the time is reset to 1½
minutes. Repeat the procedure and the light will blink twice,
resetting the timer to 2½ minutes. Repeat again for a 3½ minute
interval, etc., up to a maximum of 4 blinks and 4½ minutes.
