Outside the normal analog pressure sensor (APS) / hose checks...
Another cause for the F35 and SUD error could be your CCU (control unit). There are components that seem to fail over time and cause the F35 and SUD errors. You can replace those components yourself now...
See f35 error for more information.
I hope this helps and let me know if you need anything else!
From what i've read, anolog pressure sensor
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
Kevin
Hello &
Welcome to FixYa
Kevin
