My husqvarna sewing machine (viking 400) will not feed the bobbin - think it is out of time -- How do I set the timing?
I also am having problems with the bobbin not feeding---could you suggest what I need to do. Thanks
Sheryl
[email protected]
HI,
Do you mean how to retime it?
Loosen the screws on the main
shaft gear that goes to the hook drive gear and separate the gears.
Next put the needle in the left position and bring the needle all the
way down by turning the handwheel. As the needle comes up make the
point of the hook enter the scarf of the needle (just above the needle
eye)and hold it there while you put the gears back togeather and
tighten the screws. This should put it close to being in time. To fine
tune it you can loosen the needle bar screw (half way up the bar that
holds the needle) and adjust theneedle so the hooks point is just above
the needle eye. You may have to do this a few times in order to stop it
from skipping stitches.
I need the manual for viking husqvarna 400 sewing machine so I can identify tension dials
I need a visual of tension dial on viking husqvarna 400 computer sewing machine
I dropped the machine and need to fix the bobbin switch
