SOURCE: Pictures are coming out blurry sometimes depending on zoom
make sure there is no fingerprints on the lens glass
SOURCE: Zoom Error
I concur with rogerstone1's reply. I just replied to another post with similar information and will repost here to make sure you get the info. Don't know of a repair manual, but found the owners manual at this address:
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=833654&prodcat=829284&sscucatid=664271
Reposted reply:
I have the same camera (Fuji Finepix 345) and a problem that may have been similar. When I powered on the camera the lens would extend but as soon as I attempted to take a picture the camera lens would retract and the camera powered itself off.
The camera is now working. I followed the troubleshooting steps at this address:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Gently holding onto the lens to prevent it from retracting during power off was the solution that worked for me.
My camera's problem seemed to slowly get worse over time until it finally stopped taking pictures. At first my wife and I noticed that pictures were sometimes out of focus. It turned out that my wife takes pictures using the viewfinder where I use the LCD screen. She wouldn't notice that pictures were out of focus. If I saw that the LCD was out of focus I'd power cycle, press the zoom button to get the lens to move, and/or try tapping the camera while holding it upside down and powering it on. Eventually it got so bad that we couldn't get any pictures in focus and I ended up buying a different camera. Then last night I tried the trick about holding the lens and the camera is working again.
I suggest you first see if the camera will power on when switched into playback (picture review) mode. Move the slider to the playback position and turn on the camera. Can you review pictures? If not, then clean the battery contacts by rubbing them with a pencil eraser and replace the batteries. Try holding the power button down for several seconds, it seems like my camera is slow to power on sometimes.
If you can review pictures in playback mode you'll know the problem is not batteries, battery contacts, or the LCD display and circuitry. Is the lens stuck? To jar it free, try holding the camera upside down and tapping the edge against the palm of your other hand while holding the power button down. As mentioned earlier, this used to work for me.
SOURCE: FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
