Question about Amana 15.0 cu. ft. / 425 liter Upright Freezer Deepfreeze AFU1567A
Our freezer is about 7 or 8 years old. We went to the garage and it was buzzing a very loud buzz. What do we need to do?
  • 10,421 Answers
Hi, Remove the buzzer.
Posted on Dec 15, 2010
Loud buzzing noise and both lights on the bottom are on.
Is the buzzing coming from the compressor, or from the switch itself?
Mar 08, 2016 | Freezers
Started making a loud buzzing noise. Have tried unplugging it and turning it off and on.
Good Morning Denise, thank you for your inquiry!
From the information you have provided your Frigidaire freezer is making a buzzing noise and it will not stop. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If the buzzing continues I would be happy to research your freezer further, in order to do so I would need your model number. You can locate the serial tag (which lists your model number) on the inside wall. Once I have that information I would be happy to help you further. -Matt
Mar 08, 2016 | Frigidaire Freezers
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Why is chester deep freezer making a loud buzzing sound
Have you made sure it is at least a couple of inches away from wall? It could be the metal rack on the back may be loose, or the feet aren't exactly level... Does it only buzz when cycling?
May 22, 2014 | Haier 13.6 cu. ft. / 385 liter Upright...
My freezer just keeps buzzing non stop very loud but seems to be still working how can i stop the buzz
I think you will find that your freezer is warming up. Check the temp inside the freezer. It should be between -10 and 0 degrees. If not, your buzzer will go off until this is repaired.
Sep 15, 2009 | Frigidaire Freezers
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Jun 29, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Amana 15.0 cu. ft. / 425 liter Upright Freezer Deepfreeze AFU1567A Logo
324 people viewed this question
Top Amana Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Gil Shultz
Are you an Amana Freezer Expert? Answer questions, earn points and help others
