Hi, Welcome to FixYa. Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? If its clogged it won't allow the clothes to spin out enough due to water extraction being prevented. The insert/filter is located on most Asko washer below the main basket door behind a toe panel or square access door. Once found, turn it counter-clockwise to remove it and clean inside thoroughly. Let me know how you do or if you don't understand or even needing more assistance. Thanks for choosing Fixya and good luck. Regards, Macmarkus :)
