There is water from somewhere in my woods upright causing ice flows(6 inch buildup) on the bottom ..water around the freezer..possible causes?? noticed it mostly because suddenly all the food had freezer burn and crystals inside packages.
It sounds like you might be dealing with a defrost drain issue or a problem with the freezer's door seal. Try defrosting the freezer and clearing any ice buildup, then check the door seal for any gaps or damage. If the problem persists, you may need to consult the user manual or contact a professional appliance repair service for assistance.
There is water accumulation at the bottom under the basket it forms a thick piece of Ice that we have to break in order to remove it every second day what can I do ..
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze Kenmore Freezer Parts
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
This is usually due to a plugged up drain. If you look behind the food and shelves near the bottom you will see a small hole facing down. This can be flushed with hot water using a turkey baster until the water runs free
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around.
A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
