Question about HP DeskJet 970cxi InkJet Printer
I just had my ink cartridges refilled, but the ink light keeps blinking and the printer won't print.
  • 56 Answers
Probably needs to be reset !! go on the Internet and do a search for "How to reset my HP Deskjet 970cxi" and that will tell you what you need.
Posted on Nov 01, 2010
6ya staff
SOURCE:
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
Color Cartridge light is blinking.Cartridge is about one week old.Black one is working fine.
You need to say which printer. If it's just blinking on the printer you can ignore it. Did you recently print some photos or something that would have drained one of the colours down quickly? Many of us refill our cartridges, but the manufacturers don't recognize that so the printer keeps flashing the "ink low" message because it counts pages rather than actually measuring the amount of ink in the cartridge.
Jan 24, 2015 | Office Equipment & Supplies
My HP D1560 Deskjet Printer keeps blinking and computer says Cartridge Problems but I have refilled my ink cartridges like I have in the past---what do I do ? It won't let me print ? Ahhh Help
First of all understand what is cartridge the you can solve your problem your self in future if related same: The cartridge contains two parts 1. ink tank, 2. Pen(electronic nozzles controlled by mother board).. Ink tank contains ink & main source to pen to write,.. if ink is over you wont get any image.Ink is there but pen is not writing then no use..both conbination has work to gether to create image..As you said ink is there, but pen is not working due to ecetronic nozzles are faulty & this information with mother board, that's why its indicating that replace the cartrdige..And we can't repair it because of micro technology.
See fig: 1. Container, 2.Nozzles. 3. Electronic contacts to control nozzles..
Just replace the cartridge....
Feb 04, 2012 | HP D1560 Deskjet Printer InkJet
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
Sep 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
Sep 15, 2009 | HP DeskJet 5550 InkJet Printer
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
Color ink cartridge
Yes you need to have both carts in the printer
Jun 02, 2008 | Lexmark X2500 All-In-One Printer
Refilling cartridge
cucujo, you were not as lucky as lovetofish! Sooner or later the printer will win.
The money for printer manufactures is not in the printer, it's in the ink refills. With this in mind many printer Mfg's have added small chips to their ink cartridges. These chips track the amount of times the printer prints. The software knows you are adding ink to the cartridges. Many people find they can get around this by keeping their old cartridges & refilling. Some HP users keep as many old cartridges as three. Rotating ink cartridges. This seems to work for most printers. Suggest you try the same. Continue to fill you're ink cartridge but replace with a new cartridge. When it empties replace with another new. The next three will be re-filled ink cartridges. Always refill as soon as possible, never turn ink cartridges on their sides. Keep refilled cartridges in an airless zip-lock bag, in a cool & dark place when storing.
Mike
May 05, 2008 | Lexmark X3550 All-In-One Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
384 people viewed this question
Ekse
Thomas F. Schneider
