Question about Samsung LN-T4061F 40 in. LCD HDTV
As i am watching tv after awhile my tv gets this green snow.
  • 56 Answers
There are 3 colour guns in every TV and if one or more goes then you have what you are looking at a beautiful green screen.
Posted on Nov 01, 2010
6ya staff
SOURCE:
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
How can i fix static on my maxent lcd tv
26 inch maxent mx-26x3 and 32 inch, l2614xw02 some same parts
When i hear the word static, i think snow,
If while your watching tv and it looks like color snow pixels popping in and out all over the picture i did this to fix it.
look at main board you see a green heat sink,
left of that heat sink you see a 220 uf 16 volt capacitor that half surround by 22 uf capacitors,
change the 220 uf capacitor and snow is gone.
to get it off i just wiggle slowly back in forth until the old capacitor falls off,
then put some fresh solder on and new capacitor on and done.
use a radial electrolytic capacitor not the little metal one they had on
tc
bagabillion
Jul 11, 2011 | Maxent MX-26X3 Television
I have a Maxent 42 inch plasma. The background has gone green and there is green snow in the picture. How do I get rid of this problem?
The green snow is usually a problem with the YSUS board. In the tv itself. You can attempt to have this tv repaired by a technician. Most likely it will end up costing you as much as a new tv, except you will have an old tv, with no warranty. A new tv will have all new parts. Newer and better technology and a new warranty.
Thanks,
Lee
Aug 11, 2009 | Maxent Televison & Video
Tv goes dark Grey with vertical distortion
Hi
make sure your antenna is in correct intallation or maybe you have loose contact to antenna..
Thanks!
Feb 25, 2009 | Televison & Video
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
HD Problems
ya buy new hd antenna non powered sound like antennna messing up
Jan 06, 2008 | Televison & Video
Rca Goes Green
replace video ic on Green CRT broad,also look for leaky capacitor on same broad replace it also, If this does not fix it then you have a bad green tube!
Nov 29, 2007 | RCA HD52W59 HDTV Projection Television
Samsung LN-T4061F 40 in. LCD HDTV Logo
Jerry Greenberg
Jerry Greenberg
Ekse
