SOURCE: Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
SOURCE: icemaker dispenses crushed ice when you select cubed ice
A faulty ice maker thermostat, a choked up water line or a defective
water inlet valve could be the reason your ice maker is unable to
produce proper ice cubes. There will be water line behind the
refrigerator which you need to check for proper water flow. In case of
water not flowing properly through this pipe, clean or replace it if
necessary. Inspect the water inlet valve and get it changed if it has
broken down. Set you freezer temperature not more than 8 degree
Fahrenheit, to ensure a correct ice formation cycle.
If you take out the bin with the ice in it, right behind it there should
be a very small box with a lever in it. It doesn't exactly look like a
lever, but a piece of plastic that is in the little box, and it slides
up and down. It gets stuck down or up (I forget which). You can just
push it with your fingers, usually. Push it up and down a few times to
unfreeze it.
Take care.
