Question about LG MU-42PM11 47 in. EDTV-Ready Plasma Television
LG MU-42PM11 does not have sound. I have Cable TV. I have picture but no sound. I purchased a sound bar new.l
5 Suggested Answers
6ya staff
SOURCE:
russtash
  • 160 Answers
SOURCE: My LG MU-42PM11 popped a fuse on the zsus board. I
Hello again.
In case if you would replace fuse (it's one of two ceramic slow-burning fuses installed in holders next to each other) and it woudn't burn but TV still have no image - that means that both Z-Sus and Power Supply boards are bad. If fuse got blown again right away - usually indicates that Power Supply board still OK and does not need to be replaced.
Before go ahead and order Z-Sus board, visually check out narrow buffer board that attached to it. On other end of it you will see several flat ribbon cables that go into Plasma Panel. Make sure that you will not fined any cracked (exploded) microchips ot other electronic components or burn marks on it. Sometimes short in buffer board can cause Z-Sus short out as well. If everything looks fine - replacing just Z-Sus board would in 95% cases repair your TV.
Posted on Aug 19, 2010
Anonymous
  • 487 Answers
SOURCE: LG LCD/DVD TV no sound on TV - DVD works fine with sound!!!!
HERE is the servce manual for this TV
Posted on Jun 21, 2008
tibbenham
SOURCE: lg 42pc1dv have just purchased a lg bluray player
hi. i have the same problem with my sky HD box and the same lg tv as you,
did you solve the no sound through HDMI.
Posted on Jan 05, 2011
BeckiB_DISH
Becki Barned
  • 286 Answers
SOURCE: No picture just sound thru dish network
There are a few reasons that this could happen. The main reason would be that the tv is on the incorrect channel or input. You will want to make sure that if you are at TV1, the channel is on 3 or 4, and an input if needed, such as VIDEO 1 or 2. If at TV2, the channel needs to be on 60 or 73. Cabling is another reason this could be. You want to make sure that if you are at TV1, all cables going from the receiver to the TV are connected on the back of the receiver at the green TV1 location. For TV2, the cable needs to be connected to the HOME DISTRIBUTION output on the back of the receiver.
Becki Barned
DISH Network Customer Service
Posted on Feb 06, 2011
I have a LG TV 47LD650 that has picture but no sound out of tv speakers. If I connect an optical cable into the output and use a sound bar, will it still produce sound?
You have to go to setting and change the audio output to TV speakers for the TV speakers to work,, but, if you use a sound bar with optical connection...you have to set it also .. mine works the same way,,
Jun 19, 2017 | LG Televison & Video
Just purchased Rico bos90. Put optical cable from my lg tv to the optical on the sound bar. No sound whatsoever
You may need to configure either the TV settings or the sound bar to use the optical connection. If both have HDMI connections, you might consider that connection method as an alternative.
Aug 03, 2016 | LG Televison & Video
No sound or picture
Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
Mar 22, 2014 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
Wont retain audio settings
Try just using the optical cable alone. connecting the HDMI and the optical cables at the same time might be confusing the TV.
Mar 27, 2017 | LG 42LC2D 42 in. LCD HDTV
When I turn the tv on, the green power light comes on and then immediately turns off, (light goes red). No image or anything comes up on the screen. Never had any problems before this. Checked all plugins....
Use the remote to switch problem,if it's not works,I am sure the power board problem
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
My LG Plasma TV has sound problems on certain channels-mainly one
Get in touch with your cable operator and measure the strength of signals being received via the Cable. It can be boosted by the cable operator from their end or attach a booster on your line...............sodeep
Aug 19, 2009 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
LG Plasma Monitor MU-422PM11 Red Light Problem
Your unit is in protect mode a short circuit has occured either at x,y z board.Check fuses F52 on y Board,FS1,FS2 on Zboard.Remove P1,P2,P3,P4 if power supply voltage is normal replace right x-board.Remove P6,P7 if the power supply voltage is normal replace left x-board
Jan 02, 2008 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
No power
i used my plasma 42'' model MT-42PM11 about 3yrs ago i found out after a week that there is black middle bar on the screen how to solve this issue.
Dec 17, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG MU-42PM11 47 in. EDTV-Ready Plasma Television Logo
Ekse
RONALD CARTER JR
